WIRING GETTING HOT https://ausmini.com/forums/viewtopic.php?f=2&t=102082 |
Page 10 of 12 |
Author: | cooperess [ Sun Jan 21, 2024 2:07 pm ] |
Post subject: | Re: WIRING GETTING HOT |
I need 2.2 watt bayonet. |
Author: | DavidE [ Sun Jan 21, 2024 2:19 pm ] |
timmy201 wrote: That is a screw in. He needs a bayonet style to match his lampholders. |
Author: | DavidE [ Sun Jan 21, 2024 2:21 pm ] |
cooperess wrote: 12v 2.2W bayonet bulbs are thin on the ground on google. There is enough. I Googled "12v 2.2watt bayonet bulb" |
Author: | timmy201 [ Sun Jan 21, 2024 2:24 pm ] |
DavidE wrote: timmy201 wrote: That is a screw in. He needs a bayonet style to match his lampholders. https://minisport.com.au/products/dash- ... 4d36&_ss=r |
Author: | eightfifty [ Sun Jan 21, 2024 3:50 pm ] |
Have you taken the bulbs out and tried the wiring again just to confirm it is the panel/warning lights that are causing the problem (being careful to not create a short in the bulb holder with a loose centre terminal)? |
Author: | DavidE [ Sun Jan 21, 2024 10:31 pm ] |
68+86auto wrote: As long as you have the factory bulbs there should be no issue. Take them out to confirm what they are. DavidE wrote: Which cardboard ring are you referring to? All the indicator lights in the speedo are mounted in lampholders which are push fits into the back of the speedo dial, and thus no cardboard is in contact with any lamps. Having installed a Vinwire harness into one of my (restoration) cars, and removing an original harness in another, and re-installing it, I have no ever had the sort of issues you are experiencing. No you have a suitable wiring diagram I'd start checking the wiring in your for correct connections. Each hole for a warning light bulb has a cardboard tube between the rear panel and front face. Tube or sleeve, but not ring. |
Author: | DavidE [ Sun Jan 21, 2024 10:39 pm ] |
timmy201 wrote: DavidE wrote: timmy201 wrote: That is a screw in. He needs a bayonet style to match his lampholders. https://minisport.com.au/products/dash- ... 4d36&_ss=r Minisport says that GLB47643 in their range, which is actually a Narva product (47643), is the globe for the bayonet type holder (BA9S). 12v 3 Watt. Normally fitted to the newer type looms and globe holders. |
Author: | cooperess [ Tue Jan 23, 2024 6:20 pm ] |
Looking at my new loom, it appears the dash lighting has 3 bulb types. It would be good to know the part numbers. There are 2 blinker repeater bulbs, 1 ignition bulb and 2 panel lights and 1 high beam. NB non of the new fittings will accept the original screw in bulbs which I have been collecting, so they are useless. Also the 2 gauge bulbs. |
Author: | 1071 S [ Tue Jan 23, 2024 6:33 pm ] |
Just go to your local garage and tell them you want 2 odd watt bayonet bulbs.... Its not rocket science. Cheers, Ian |
Author: | DavidE [ Tue Jan 23, 2024 8:45 pm ] |
cooperess wrote: Looking at my new loom, it appears the dash lighting has 3 bulb types. It would be good to know the part numbers. There are 2 blinker repeater bulbs, 1 ignition bulb and 2 panel lights and 1 high beam. NB non of the new fittings will accept the original screw in bulbs which I have been collecting, so they are useless. Also the 2 gauge bulbs. Ask Vintage Wiring Harnesses what the part number/s for the suitable bulbs are. Alternatively, ask them for the industry recognised designations for the bulb holders are, and the associated wattages for each. Put your now useless bulbs on eBay and flog them off to grateful users. |
Author: | DavidE [ Wed Jan 24, 2024 7:08 am ] |
cooperess wrote: Looking at my new loom, it appears the dash lighting has 3 bulb types. It would be good to know the part numbers. There are 2 blinker repeater bulbs, 1 ignition bulb and 2 panel lights and 1 high beam. NB non of the new fittings will accept the original screw in bulbs which I have been collecting, so they are useless. Also the 2 gauge bulbs. I have previously given you the information of the globe type as installed in the rear of the speedo casing (as sourced from the Minisport ADL website). As for the indicator repeaters, this comes from the same source. "[GLB47281] These globes go into the side indicators on the dash as fitted to the MINI K or Mk2 Cooper S (Green indicator illumination). Specs:Input range: 12VPower: 2WSize: 6.5mm wide x21mmBase Type: BA7S T-6.5mm". 47281 means you can eyeball them in a blister pack at a Narva stockist. I have pulled apart one of my spare lampholders to verify. As for the bulbs in the gauges these are those that you have in plenty. Not one of the spare parts catalogues I have from vendors in decades past have any useful information. My Driver's Manual AKD3891 is best but the bulb designators tend to be quite archaic, and added prefixes tend to instill confusion. |
Author: | cooperess [ Wed Jan 24, 2024 8:32 am ] |
Ok guys, I get the messages, thanks for your help with the non standard bulbs.. |
Author: | simon k [ Wed Jan 24, 2024 5:58 pm ] |
the dash lighting is on a separate circuit to the headlights anyway - it's the red wire that goes to the parkers and tail lights - not the blue wires |
Author: | cooperess [ Sat Feb 03, 2024 10:21 am ] |
I now have all the dash Narva bulbs and will see if they all work. Have ordered new light switch because the new switch I was using got hot. |
Author: | cooperess [ Sun Feb 04, 2024 10:18 pm ] |
I made up my own stand alone headlight wiring loom today, so the headlights are not within the cars loom. This made no difference to dip switch (all wires used) or the light switch (only 2 wires) or the earth wires, they all started to get hot. The dip switch is new. The headlight switch is a new Lucas branded one. The two headlight looms are new from Karcraft. This means my new loom is not responsible for my heating earth wires etc. Still the mistery continues. |
Page 10 of 12 | All times are UTC + 10 hours |
