It is currently Mon Jul 28, 2025 7:30 pm
PostPosted: Sun Apr 24, 2016 10:44 pm
Hey guys just after some photos on how you installed your oil cooler.
I do have the clubman cooler kit but not sure if i want to use it or go with something custom.
PostPosted: Mon Apr 25, 2016 11:33 am
Is this for a clubman GT?
There should be two tabs welded to the body, which accompanied with a bracket that bolts to these tabs and the front valance between the number plate holder brackets holds an oil cooler.
I ran a cooler in my 78 leyland mini a few yrs ago and just made two short plates from steel and bolted the cooler to the tabs and drilled a couple holes in the top of the front subframe and bolted it to it.
Dont have any photos at hand of these
PostPosted: Tue May 10, 2016 10:24 am
im not sure how these two brackets work and how they mount to the car?
Do you need to trim them down ?
PostPosted: Tue May 10, 2016 10:29 am
They would be a generic strapping that you can cut and bend to suit your needs.
PostPosted: Tue May 10, 2016 10:31 am
thanks that's the answer I was after I didn't want to paint them then find I had to bend them..
Anyone have photos of there install ?????
PostPosted: Tue May 10, 2016 2:22 pm
Early clubmans and GT's have a different bracket at the front subframe mounting points that allows a little bit more room (around 1/2" if I recall) to fit an oil cooler between the subframe and front panel.
If you don't have the early setup and the GT oil cooler brackets spot welded onto the front panel then you'll need to attach the oil cooler to the front of the subframe. I'd ignore using the generic brackets and make up a couple of much smaller and thicker brackets and bolt to the subframe - things might get a bit tight but it will fit.
Rod
PostPosted: Tue May 10, 2016 6:48 pm
Is this of help?
viewtopic.php?f=2&t=86085
