It is currently Tue Jul 29, 2025 12:39 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 21, 2016 9:31 am
we don`t use the facets anymore, the cheapo ebay ones were leaking & stopping on us so we just don`t use em
we have rotory types now & they work a treat, quiet, reliable & fairly cheap at $110 each
cylindrical type, one strap around & bolt & fit fuel filter before it & away you go & don`t look back
but,,, i`m with the good Doc here, sounds more like a condensor or coil or points
however, the 1275LS was renound for fuel vapourizing
the pipe from the pump runs right beside the exhaust pipe
so gets hot & vapour in pipe, pump won`t pump because the vapour squashes up & pushes back
check the fuel pipe from the pump to the carb & see how close to the exhaust pipe it is
PostPosted: Fri Apr 22, 2016 7:01 pm
It's close !. And we fitted Maniflow LCB extractors. Hmmmm
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
