It is currently Tue Jul 29, 2025 12:40 am
PostPosted: Mon Apr 18, 2016 8:06 pm
My Oil filter housing the spin on type is leaking oil
Its a 1300 land crab spin on filter housing.
I have read that high reving minis can have problems. I have been driving it with passion. Its a 1360 modified engine etc.
I have checked the housing for cracks etc, new gasket, its tight on the block, Wipex filter.
any thoughts.
PostPosted: Mon Apr 18, 2016 8:20 pm
Is it the gasket flange, or a crack in the body? The stock spin on gasket is flimsy, I made my own.
File the flange to ensure it's flat.
PostPosted: Mon Apr 18, 2016 8:28 pm
Thanks Kev
The gasket is of a decent quality.
I did check if the flange was flat with a steel rule and some feeler guages and it looked fine.
Theres not much too go wrong. It was in the engine bay fire I had so may be its warped a little.
I may have to find another one and swap it out.
It did happen after a reasonably hard run
PostPosted: Mon Apr 18, 2016 9:15 pm
I would file it to ensure it is flat. Even over tightening the bolts can bend it. The fire would maybe have warped it.
