It is currently Tue Jul 29, 2025 1:46 pm
PostPosted: Mon Mar 21, 2016 6:38 pm
Hi everyone,
Another question that has probably been asked a million times before (however my searches didn't turn up anything useful).
Is there a simple way to remove the oil pressure switch without having to remove the dizzy etc??
My switch seems to be leaking oil when the car is running, however I don't actually seem to have the room to get a spanner in there to remove the old one.
On a side not as well, has anyone had any experience with the new oil pressure switches? The new one seems much smaller than the original that is on there, however I haven't actually been able to get the old one off...so the thread could be the same size.
Thanks in advance,
Richard
drugstore-catalog.com
PostPosted: Mon Mar 21, 2016 9:05 pm
no, but put a scratch or pencil mark on the dizzy and the mounting plate so you can put it back where it came from and it'll be fine...
the thread is 1/8" BSP
PostPosted: Tue Mar 22, 2016 4:55 am
It should not be real tight, grab the body with multigrips. Or, heat & bend a spanner to fit in there
PostPosted: Tue Mar 22, 2016 3:49 pm
Ok, sounds not too bad.
The thread is hopefully the same, its just the old switch unit seems so much bigger.
Any idea what size spanner? I've gone to the biggest I have lying around but can't find the right one. Maybe I just can't get it on there properly though....
PostPosted: Tue Mar 22, 2016 5:41 pm
Multi-grips. That is what you need.
PostPosted: Tue Mar 22, 2016 8:49 pm
I use a special deep socket which I purchased from a cheep tool shop. It was made for the job and works a treat. No need to take any crap out of the way - just the grill if you don't have the correct length extension bar.
PostPosted: Tue Mar 22, 2016 9:18 pm
Sounds good. I might give the multi-grips a go first seeing as I already have them.
Do you know what size socket it is (just incase).
PostPosted: Tue Mar 22, 2016 9:48 pm
It does two size's. 1" and 1 1/16"
It has a special hex to suit the switch.
The brand - good old chrome vanadium.
PostPosted: Wed Mar 23, 2016 2:25 pm
that's not a brand - that's what it's made out of :D
PostPosted: Wed Mar 23, 2016 3:24 pm
I just assumed he was being a smarty pants :p
Users browsing this forum: Bing [Bot] and 105 guests
