It is currently Tue Jul 29, 2025 9:29 pm
 Post subject: Pressure plate
PostPosted: Sat Mar 05, 2016 3:34 pm
Did Repco make uprated clutch pressure plates or were they based on original fitment? just trying to work out what is in my gt motor
 Post subject: Re: Pressure plate
PostPosted: Sat Mar 05, 2016 4:42 pm
If the clutch did not slip it must be OK.
"Let us remove your "SHORTS"
PostPosted: Sat Mar 05, 2016 6:24 pm
The Repco catalogue from 1984 shows the same pressure plate on the Mini and the Cooper S/Clubman GT. (part number deleted)
It shows a different driven plate though.
PostPosted: Sat Mar 05, 2016 6:58 pm
Couldn't tell you I pulled the motor down was debating to use it again or go to a orange one
PostPosted: Sat Mar 05, 2016 8:39 pm
Measure the thickness of the diaphragm spring and compare it to a blue dot S one. I think same or thicker. I don'thave one here, will check tomorrow.
PostPosted: Sat Mar 05, 2016 9:25 pm
I found some more info in some other Repco catalogues. I don't expect anyone is interested though.
PostPosted: Sat Mar 05, 2016 9:32 pm
There is a part number on the diaphragm will grab it tomorrow
PostPosted: Sun Mar 06, 2016 9:03 am
I'm "reasonably curious"... but you're right, I don't know if it'd stretch to "interested"....
PostPosted: Sun Mar 06, 2016 2:21 pm
The Repco one I have the spring measures 2.35mm thick.
My AP grey dot one is 2.5mm.
Both blue dot Cooper S ones here measure 2.10mm.
I seem to remember this Repco one was the same thickness as an orange dot one.
PostPosted: Sun Mar 06, 2016 5:21 pm
I will measure my orange and repco one
PostPosted: Sun Mar 06, 2016 6:21 pm
Can't find my orange must have used it repco one is 2.30mm and a new blue dot is the same i have a light green one that is 2.10mm
PostPosted: Sun Mar 06, 2016 7:38 pm
Hmmm... the 2 I have here are definitely blue dot? Took one out of an S last week. I throw old green dot ones away...! Unless I am going colour blind and they are green..! :?
Users browsing this forum: Phil 850 and 106 guests
