It is currently Wed Jul 30, 2025 10:34 pm
 Post subject: Dash lights gone
PostPosted: Mon Feb 08, 2016 8:35 pm
I have a three dial cluster in my mini and tonight the speedo and taco lights stopped working. The middle dial (fuel and temp gauges) still has a light just the two outer ones have given up.
Any ideas as to why this would happen?
 Post subject: Re: Dash lights gone
PostPosted: Mon Feb 08, 2016 9:25 pm
I would be looking at the bulbs, circuit board or a bad connection with the bulb holders.
PostPosted: Tue Feb 09, 2016 4:56 pm
Yep I'm pretty sure they are all on the same circuit check bulbs :)
PostPosted: Tue Feb 09, 2016 5:09 pm
These lights come from a common source, and the negative return wire is also to a single point on standard wiring (anything goes if someone has modified the wiring however). You will need to follow the wires to their source to find the break. It won't be far from the speedo.
PostPosted: Tue Feb 09, 2016 8:15 pm
Thanks boys, now I just have to get to it and fix it.
