It is currently Wed Jul 30, 2025 10:49 pm
 Post subject: 29D Distributor position
PostPosted: Sat Jan 30, 2016 5:35 pm
Have been looking through old posts regarding distributors but really couldn't find what i was after
My Question is
What is the correct position of the Dist body when installed in the block (Aussie Lucas 29D)
That is the position of the 2 cap clips
Mine the bottom clip wont undo due to it hitting the oil cooler
So i think its not installed correctly
Anyone got some photos or scans out of a proper manual
my Leyland Aust one is hopeless
1970 MK2 Cooper S
PostPosted: Sat Jan 30, 2016 6:00 pm
It really doesn't matter how the dizzie is oriented... as long as the points are opening when the lead the rotor is pointing to is attached to the No 1 plug when No 1 piston is at the top of its compression stroke.... (and, of course, the clips don't get in the way ... :wink:
The easiest way is (IMHO) would be to move the No 1 lead to the old No 3 dizzie cap terminal and then rotate the dizzie clockwise (90 odd degrees) until the rotor is pointing at the "new" No 1 (old No 3)...... The rotor arm will not move as the dizzie rotates around it.
You will then just need to check the timing at the new position.
You could remove the dizzie and the drive and rotate the drive a couple of teeth but the first solution is less messy (IMHO :)
Cheers, Ian
PostPosted: Sat Jan 30, 2016 6:31 pm
1071 S wrote:
You could remove the dizzie and the drive and drop it in the sump.
Fixed. :mrgreen:
I have seen so many people drop the dizzy drive into the sump when trying to move the dizzy to the correct position. On one forum a bloke cut a hole in the gearbox to get the drive out! (he patched it with plywood)
PostPosted: Sat Jan 30, 2016 6:42 pm
PLYWOOD! I hope he used a good marine grade like I use for rust repairs in the floor.
PostPosted: Sat Jan 30, 2016 7:20 pm
On an S engine, you just need to pay a little attention to the clip position because the oil cooler and oil cooler hoses make it a little tricky. So sideways is easier as you can't get your hands underneath.
PostPosted: Sat Jan 30, 2016 10:50 pm
My MK2 S had the dissy clips at 10 and 4 o'clock
AKA - GTOGREEN1969
PostPosted: Sun Jan 31, 2016 7:02 am
Thanks for the photo
thats all i was after
Easy to turn the dist and move the leads on the cap to suit
The XR700 Electronic ignition module has a static timing red light to help set the timing
1970 MK2 Cooper S
PostPosted: Sun Jan 31, 2016 7:13 am
Nice Spark Plug leads
Are they NOS
1970 MK2 Cooper S
PostPosted: Sun Jan 31, 2016 8:41 am
No, Poeee had a set on an engine in his shed once upon a time. They do come up on eBay though, usually connected to entire distributors dragged out of the nether regions of sheds and covered in red dirt. You have to look carefully!
These ones were wiped and cleaned using thinners and the copper contacts (they're copper cored, not carbon/cotton) cleaned with vinegar then washed clean.
