It is currently Fri Aug 01, 2025 4:10 pm
 Post subject: Re: Identify the engine
PostPosted: Sat Jan 23, 2016 9:52 pm
Goldbrocade_62 wrote:
Were they at Telopea?
Yes they were. Long time ago...
PostPosted: Sat Jan 23, 2016 10:11 pm
What sort of reputation did they have doc? And supercooper it most definitely is a 1275 head..... I'd like to know why you say it doesn't look like one? All you need to do is look at the distance between the thermostat housing and the rapper cover to notice the difference to a small bore without checking numbers.
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Sat Jan 23, 2016 10:15 pm
Could be wrong but Thermostat end doesnt look right for a 1275 imo.
Head has pollution ports on front.
Now with 2 extra ports!
PostPosted: Sat Jan 23, 2016 10:36 pm
Definitely 1275 ls or moke
PostPosted: Sat Jan 23, 2016 11:38 pm
SuperCooper wrote:
Doesnt look like a 1275 head
It is a 1275 head. The angle of the heater outlet changes and the position of the thermostat housing bolts also change from small bore to big bore. Not saying its a 1275 engine because you can fit a 1275 head on a small bore engine.
Here is a cheat sheet for heads.
PostPosted: Sun Jan 24, 2016 7:13 am
PM sent.
PostPosted: Mon Jan 25, 2016 2:51 pm
High heel ninja
Ask Aaron what they were like!!!!
Doogie
PostPosted: Mon Jan 25, 2016 3:26 pm
Doogie
I mentioned that in the PM...! :wink:
Users browsing this forum: Bing [Bot], winabbey and 101 guests
