It is currently Thu Jul 31, 2025 7:45 pm
PostPosted: Sat Jan 23, 2016 3:37 pm
Hi Guys
would anyone know what the track width of a 1966 with 13x7 minilight?
wayne
1966 Deluxe G13B turbo
PostPosted: Sat Jan 23, 2016 3:54 pm
Depends on offset of wheels and what brakes you have.
PostPosted: Sat Jan 23, 2016 4:10 pm
That is exactly what my Orange mini is a 66 with 13 X 7s. I have never measured it. It has 8.4" Discs. Mine has EPS too.
"Let us remove your "SHORTS"
PostPosted: Sat Jan 23, 2016 5:00 pm
hi guys
it has camira conversion, not sure on the offset.
i was told its 1500mm, just wanted to compare as im looking for a trailer and most guys have standard wheels and fit in a 5ft wide trailer but i know the wheels hang out a bit more with the 13x7 but i didnt know how much
i havent picked up my car yet so i havent been able to measure for myself and im on the look out for a cheap trailer just want to make sure its not to tight a fit
wayne
PostPosted: Sat Jan 23, 2016 5:21 pm
Thats heaps easier.
For a trailer you want 1600mm minimum - that'll give you only about an inch of clearance on each side though.
PostPosted: Sat Jan 23, 2016 5:32 pm
Mine is about 1560 wide with 13x7 wheels and the width of the trailer between the guards is 1680
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jan 23, 2016 7:58 pm
hi guys
thanks for the info, confirms what i needed to know
wayne
