It is currently Fri Aug 01, 2025 4:11 pm
PostPosted: Thu Jan 21, 2016 9:15 pm
I have a body with the RH wing replaced with a heritage panel.
The LH (original) panel takes the usual square hole plastic retainer type nut, to which the headlight bucket attaches:
The new panel has round holes instead:
Should I just find a nut and bolt [or screw] that works here or is there a better method I should use?? Thanks
PostPosted: Thu Jan 21, 2016 9:16 pm
unfortunately :( i have seen large self tappers used ??
65 panel van Sprog
73 panel van Iggy
PostPosted: Thu Jan 21, 2016 9:22 pm
Yes I have seen that has been done in various locations on Minis and I've wondered what is factory and what is 'altered'?!
Did they use those here from factory?
This panel is probably similar to late UK Minis I assume - maybe I should search the UK parts websites.
PostPosted: Fri Jan 22, 2016 4:53 am
I just done up a sprite and it uses nut and screw
PostPosted: Fri Jan 22, 2016 10:17 am
I'd file them square.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Jan 22, 2016 11:32 am
Yeah righto, sounds like I'll just have to use one of those workarounds and either file it square and grab some plastic inserts or use a nut and bolt. Cheers
PostPosted: Fri Jan 22, 2016 1:03 pm
Supercheap sells the square plastic inserts in packs on the bolt rack.
PostPosted: Fri Jan 22, 2016 2:03 pm
Oooh nice tip, alright I might do the file plus square plastic insert method. At less then it will be all consistent and local style. Thanks all.
Users browsing this forum: Bing [Bot], winabbey and 102 guests
