It is currently Thu Jul 31, 2025 5:33 pm
 Post subject: Engine back in
PostPosted: Fri Jan 15, 2016 11:44 am
Needing some info on engine installation. My body is almost ready to paint,my sub frames are complete & motor teady to go. What is the best or easiest way to re install the motor? Should I put the motor in the sub frame & lower the body over the lot or install the sub frame & drop the motor in? Thanks for any advice.
Cheers Kath. [ 69 Cooper S]
 Post subject: Re: Engine back in
PostPosted: Fri Jan 15, 2016 11:49 am
I've done it both ways.
Nowadays I would fit the subframe first. Then lower the motor in with some stiff cardboard against the radiator to protect it.
Yes the factory did it the other way, but that was on a production line with jigs to keep things straight.
PostPosted: Fri Jan 15, 2016 4:30 pm
I did mine by fitting to subframe on a trolley jack and 2 of us lifted the front up while my wife slid the motor underneath.
Was surprised how easy it was.
To have a true objective opinion on all things motoring, one must experience a variety of configerations and combinations on a regular basis in an effort to not form an excessive attachment... Oh who am I kidding...
PostPosted: Sat Jan 16, 2016 8:08 am
We have found that our chain block allows micrometer-like precision in either raising or lowering the engine, so much so that we only use rags (sections of old towels, or the like) to protect the paintwork. Raising can be a one man job, but two are better when lowering.
Users browsing this forum: Bing [Bot] and 84 guests
