It is currently Fri Aug 01, 2025 1:23 pm
PostPosted: Sun Jan 10, 2016 9:25 pm
Essentially my query is as above, I can remove the wiper motor and the left hand pivot/mechanism, but the right side it seems impossible to rotate this so that it clears the hole without removing the bonnet hinge. Are there any tricks to this? Thanks, Jon.
PostPosted: Mon Jan 11, 2016 6:43 am
PM sent
"Let us remove your "SHORTS"
PostPosted: Tue Jan 12, 2016 11:14 am
Well I did get it off fairly easily when I disassembled the wiper box, but whether I can get it back again is a different story... I wonder if they welded the hinge bracket in afterwards?!
PostPosted: Tue Jan 12, 2016 11:43 am
I have found that by rotating the underside spacer 180 degrees it makes the whole job simpler. When the spiggot is poking out of the scuttle, you can then turn it back to its proper position.
PostPosted: Tue Jan 12, 2016 8:30 pm
Yep, tried rotating the spacer etc. The problem was that the hinge was getting in the way of the tube and preventing it moving downwards when it was rotated. It's only a few inches from the box. Jon.
PostPosted: Wed Jan 13, 2016 11:38 am
Taken the bonnet off?
PostPosted: Wed Jan 13, 2016 12:14 pm
you have to loosen the nuts holding the wiper drive gears together beneath each bit that protrudes the scuttle then you can rotate the sleeve to a different orientation to clear whatever you need to. Take your time, do it in the shade and don't swear at it and it will happen. Its a ning nong of a job especially when you're trying to reinstall it and not damage brand new paint work. @#$%&!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Jan 13, 2016 10:53 pm
Yes, the bonnet is off but that hasn't helped me rotate the wiper box....!
PostPosted: Thu Jan 14, 2016 9:03 pm
I also loosen the nuts that hold the wiper box's together. 3/8 nuts from memory. This lets the tube between the two box's move around / twist, as it has a bend in it.
PostPosted: Thu Jan 14, 2016 9:12 pm
That's what I was trying to describe. The sleeve is in 3 sections, you have to loosen them all to manipulate the assembly out....
67 Deluxe
Dry suspension
Users browsing this forum: slacko and 87 guests
