It is currently Fri Aug 01, 2025 1:20 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Jan 12, 2016 11:59 am
They didn't exist when I started and the OH&S breed of people didn't exist either....
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Tue Jan 12, 2016 2:06 pm
I used MEK and Carboline at work pre ohs. Paying for it now. :sad:
PostPosted: Tue Jan 12, 2016 7:40 pm
deluxe67 wrote:
Toluene or methyl benzene is not carcinogenic. Besides having a great Octane Number, it is a brilliant solvent. It WILL dissolve fuel lines and rubber gaskets etc if used in some of the ratios mentioned above. Ditto Benzene, however Benzene IS carcinogenic...
Quote from Health Canada (Canadian Ministry of Health) ....".The weight of evidence indicates that toluene is not genotoxic in mammalian or microbial systems. It has been classified, therefore, in Group IV-C (probably not carcinogenic to man) of the classification scheme developed for use in the derivation of the "Guidelines for Canadian Drinking Water Quality" (EHD, 1989)."
Somewhere else there's a disconcerting note to the effect that "abuse" of toluene can cause "testicular atrophy". I don't know what constitutes abuse ..but it doesn't sound like a good idea..
The fact that its not too bad is good news as its a major constituent of Oz motor fuel. However, as noted previously, it has a significant effect on rubber which means the proportion needs to be pretty stable. Too much and your fuel lines go soggy - and fall off. Too little and fuel lines can dry out ...and fall off :? A few years ago there was a spate of engine fires in NZ that was traced to a bad batch of fuel out of Singapore ... too much toluene. But the octane was good :roll:
Cheers, Ian
PostPosted: Tue Jan 12, 2016 7:46 pm
I dunno, but there's no shortage of people dealing with health issues as they thought the safe chemicals they used back in the day have turned out to be quite the opposite. I wouldn't trust much of anyone on the subject that any chemical ending with an "...ene" is safe. The weight is against them all.
I keep my hands and nose out. My employer won't be there to comfort my family once I shuffle on from a premature death.
While I am on it. I like turps in the washer. It is a little higher in the cracking tower so dries a little quicker, leaves no oily finish and also (important in an attached garage), it doesn't stink.
