It is currently Fri Aug 01, 2025 1:17 pm
 Post subject: VH Brake Booster Issue
PostPosted: Fri Jan 01, 2016 6:28 pm
Took my mini out for a quick run this arvo ( disc brakes , VH44 booster ) i jumped back into it after going to the bank , went to pull up at an intersection and the brake pedal felt really hard all of a sudden , did a couple of brake tests in it , yep pedal pressure was way harder than normal , first thought brake booster has sh!t itself , took it home , checked for obvious issues everything fine looking at it.
I noticed that when i put my foot on the brake pedal when idling the engine revs increase , i'm thinking diaphragm knackered , any thoughts?
PostPosted: Fri Jan 01, 2016 7:01 pm
Check the little elbow hose Under the cylinder on the booster. I don't know what it is called. it is only about 3/8 in diameter. it could be cracked or split and sucking air.
"Let us remove your "SHORTS"
PostPosted: Sat Jan 02, 2016 10:07 am
With the engine off, put your foot on the brake pedal, now start the car. Does the pedal go down a little?
PostPosted: Mon Jan 04, 2016 7:15 pm
Finally got 5 mins to have a look around the booster today , i can't see anything out of the ordinary with the small elbow hose , nor the hose that runs back to the inlet manifold .
It has a high brake pedal without engine running , start engine , no decrease in pedal height , which leads me to think that something is going on internally with the booster , just no idea if it's in the
diaphragm or the m/cyl part .
With engine running , depress brake pedal ,engine revs increase by a couple of hundred rpm's :? .
PostPosted: Mon Jan 04, 2016 8:46 pm
Sounds like diaphragm has a hole. Kit time...
