It is currently Tue Jun 24, 2025 11:31 am
 Post subject: Ram Tubes!!!!
PostPosted: Sun May 23, 2004 6:05 pm
I know this should be in the Forsale/Wanted section, it will be also.... but im after some ram tubes to suit a pair of 1"1/4 SU's.... and I have some ramtubes for a weber forsale/swap...check out bthe foresale section....
does anyone here run ramtubes? Dr Mini?
pics would be cool
-Cam :roll:
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Sun May 23, 2004 6:53 pm
I don't have room for ramtubes as I run the Dellorto without a Weber box. :?
I made some flush to backplate stubstaks to go inside the Ramflo filter, as per Vizard- they are only about 5mm long.. and yes they DO work.. 8)
