It is currently Tue Jun 24, 2025 6:51 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Fri May 14, 2004 12:31 am
Arent worn syncros a very usual problem in a mini, there are heaps of them out there with sticks vibratiing in 3 and whining in 2nd - you just gotta learn how to toe-in-heel down shift and 3rd to 2nd is easy. It can last for many ears - just depends on how you come to deal with it.
Rebuilding a box would cost you around $1000 just in parts plus labour . But with s'hand gearboxes its much easier to see if its stuffed - there is a discernible physical wear and it can be examined when the box is off. BTW if youre getting a 1275 engine (even if its the non Cooper ones - ie 1275LS \ Marina etc) even with fairly basic tuning you'd feel that the standard gear ratios are too low and your 1st and 2nd are of not much use anyways.
PostPosted: Sat May 15, 2004 12:17 pm
a friend recond an engine from a close friend for $650. that was a mate's thing.
i got quotes of $1300
i say if the gearbox is the only prob then fix it. if pretty much everything is worn, get another engine. you can probably find a good recond engine for about $2000
Inconspicuously Conspicuous
PostPosted: Sat May 15, 2004 5:36 pm
1200 for a 1275?????? DAMN, gimme his number. I coulda bought three of em for the price that was paid for mine.
"He's always been a dickhead, He always is a dickhead, He will always be a dickhead. So stop complaining when he acts like one."
Users browsing this forum: Majestic-12 [Bot] and 86 guests
