It is currently Sun Jun 22, 2025 8:02 pm
 Post subject: Gearboxes and clutches
PostPosted: Fri Apr 09, 2004 3:45 pm
I've been told mini's are hard to get into first/reverse sometimes, I'm guessing they don't have any synchomesh for those gears?
I have alot of trouble getting it into reverse and first, but also when in first or reverse and I've put my foot on the clutch for a minute or two (say at lights) it starts to engage and it's difficult to get out of gear. I adjusted the clucth according to Gregory and it doesn't seem to have made a difference.
Any help!
PostPosted: Fri Apr 09, 2004 4:10 pm
Sounds like clutch is dragging- you probably have a fluid leak or bad seals- either in the clutch master cylinder, or slave...
PostPosted: Fri Apr 09, 2004 4:22 pm
Take a look at the slave cylinder first. Out of the 3 Mini's I own, one I have had to reco the slave cylinder and the other has a siezed one!
PostPosted: Fri Apr 09, 2004 5:08 pm
It does look like the slave cylinder may be leaking. Is it hard to reco (or expensive?)
PostPosted: Fri Apr 09, 2004 6:00 pm
No, it's real easy, as long as the bore is not pitted.
Strip it and check- clean bore with some wet/dry paper- (or hone it if U got one)- usually it's just the rubber seal is old and worn out. Kit is cheap, so is a new cylinder! :wink:
PostPosted: Fri Apr 09, 2004 6:09 pm
Thanks, will do. :)
PostPosted: Fri Apr 09, 2004 7:29 pm
Dont worry about reconditioning the one u have buy a whole new bastard i picked up mine off www.minidirectaus.com for 66 bux including shipping to adelaide took about 2 weeks and just gets put straight in.
12 Months ?????????????
PostPosted: Fri Apr 09, 2004 8:05 pm
$49.64 at Karcraft in Sydney, incl GST.
email is [email protected]
8)
PostPosted: Fri Apr 09, 2004 8:43 pm
Thanks guys, will try that. :)
Users browsing this forum: No registered users and 118 guests
