My first MK2 S had K-mac (hydrolastic) front and rear bars when I bought it in 1976, installed by previous owner (original owner). My current resto MK2 S did have holes drilled in the rear subframe for a rear bar, though not fitted. I am installing Selby dry suspension sway bars on this car, having made brackets for the rear arms per pics below. K-mac bar on original car had pressed steel brackets mounted on rear bump stop bolt, with links dropping down to bar. Use of a rear anti-roll bar increases roll stiffness, therefore helping reduce understeer apparently.
_________________ 1970 Mk2 Cooper S under restoration
