eightfifty wrote:
If you put a bit of welding wire up the tube it should only go as far as a couple of mm into the space behind the side cover before hitting the baffle. If it appears to be going all the way inside to the tappet chest, then that's a problem of course. That oil filler cap looks like a sealed one (I think the vented ones have a message on them to change every so many thousand miles). Theoretically, your set up should work as shown if the baffle is there. On a standard 850 with metal air cleaner housing, the passage into the air cleaner inner is reduced to 5/32". This has obviously been "well designed" and the small orifice at the aircleaner end must serve to increase the velocity of the air stream there. On that large plastic air cleaner, the drawing does not show this orifice so perhaps this has something to do with it. You might also consider that there is a high pressure oil gallery to the rocker shaft going up through the head gasket at near the side cover top left side and oil can seep out and run down the outside of the block.
Thanks eightfifty.
The filler cap is a non vented one and I've checked the tappet chest cover for a baffle and there is one. I used a zip tie and it pretty much stopped at about the length of the pipe on the cover.
The air cleaner inlet for the rocker cover hose is about 3/8" ID so maybe a small restriction would make it work better. In my reply to Dave (Steam) I asked about the main air intake diameter between the metal one I have and the standard one for an 850. I'm thinking that the one for the 1 1/2" SU might be bigger than the one for 1 1/4" SU as the bigger carb is designed for bigger engines and therefore needing more air.
I would appear that the chest cover design I have wasn't all that successful as was changed to ones with a rise up before dropping down in order to prevent any oil coming out of the cover to go out the pipe and would instead drain back into the motor. In hindsight, it would have been better to fit one of the later ones which I can still do if all else fails.
My plan at this stage is to get a good connection between the air cleaner and the rocker cover, check to see if I need to restrict either that connection or the main intake part of the air cleaner body to allow a bit more suction from the rocker cover and modify the current hose on the chest cover to include a drain part and a free to air part. Now I know that the purpose of the cover is to provide air to assist with breathing, then maybe as a result of putting a long length of rubber hose on the end of the chest cover pipe, I've made it too hard for any air to be sucked in and now the cover is effectively not doing it's intended job. The hose finishes below floor level and when driving would create a vacuum in the hose I reckon instead of allowing air to be sucked in.
Here's a sketch of what I'm thinking of doing. The open to air part of the T would be as close as possible to the end of the cover pipe and would allow for air to either be sucked in or blown out if the crankcase pressure is too high (act like a breather). I'm thinking that most of the oil in the discharge would run straight down the hose and collect in it, ready to be drained.
I possibly can't be any worse off than what I am now and hopefully catch at least some of the oil to reduce the mess it's making. If that doesn't work, I could fit a later model chest cover with a riser pipe on it which should keep the oil in the motor.
Cheers Rocky
