It is currently Fri Jun 20, 2025 5:26 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 19, 2025 4:29 pm
In the end it was the module. The replacement I got decided to play up.
I did take the opportunity to tear down the dizzy though, clean it up and set the end float, so the car is running a sweet as a nut now. A nice addition from all this is the Accuspark Blackbox Mk3. It has a nice multispark function at start up (five sparks at startup. You can hear it through the block, its like a welding spark). There's a vacuum pickup on it was well, which would take a vac from the twin SUs somehow. It might be cool to play with that option to even out the idle.
PostPosted: Fri Mar 21, 2025 1:04 pm
Some modules I have found to be height critical. Relative to the magnet ring. Twice I've needed to pack up the magnets with a plastic washer, once I needed to pack the module up. Chinese made dizzies vary compared to a real lucas 45D, however that was the one which needed the module packed up.
Somebody should put an alignment mark on the module..!
PostPosted: Tue Mar 25, 2025 4:53 pm
I think you might have nailed it. I pulled the dizzy down to shim the float that was apparent in the shaft. Once I did that the problem went away.
Users browsing this forum: timmy201 and 96 guests
