It is currently Mon Jun 23, 2025 7:21 am
 Post subject: tyre choice
PostPosted: Wed Dec 06, 2023 6:38 am
What are the closest modern tyre choices for Mk1 cooper S 1275s?
 Post subject: Re: tyre choice
PostPosted: Wed Dec 06, 2023 7:32 am
There’s actually quite a bit of choice at the moment in 10” tyres
Falken in 145 and 165
Blockley in 145 and 165
Yokohama GT Special 145
Yokohama A008 165
Aquajets in 145 and 165
Dunlop R7 165
Are you after a performance tyre? Period looking tyre?
There’s some photos and details here
https://www.johnbrownwheels.com/tyres/10-tyres
PostPosted: Wed Dec 06, 2023 5:19 pm
Period looking I think, but maybe there's a compromise between the two?
PostPosted: Thu Dec 07, 2023 7:32 pm
I am not sure if you are asking about what choices there are for minis, which timmy has covered, or whether you are asking for recommendations.
For recommendations I think the Yokohama A008 was one of the best tyres I have ever had. The set I had lasted for about 17 years and only changed because of their age. Performance was more than adequate for my driving; they wore exceptionally well and looked fairly conservative except for the asymmetrical tread pattern of holes around the outer edge.
PostPosted: Fri Dec 08, 2023 7:41 am
The Falken 165/70s last forever but are crap in the wet.
Falken 145 are OK in the wet I have 2 on my boat trailer. 14 years old and still good. No cracks either.
PostPosted: Fri Dec 08, 2023 8:33 am
I have both A008 and falkens here and both are good solid tyre choices but I am not sure if the falkens are still available.
Cheers Dave.
PostPosted: Fri Dec 08, 2023 9:46 am
Most Mk Is came with Dunlop SP41s ... which have no modern equivalents (AFAIK). Early (or UK) cars had SP3s which the current Blockley's replicate. Later Ss (probably Mk IIs) could have come with Dunlop Aquajets - which are still available.
Factory fitted tyres didn't last too long :)) and there were quite a few aftermarket options from Pirelli, Goodyear and Firestone (and probably others). In the UK I had Michelin ZXs on my 65 S. Horrible tyres but you couldn't replace them because they never wore out (no matter how hard you tried :)
Anyone remember when 165/70s became available??
Cheers, Ian
PostPosted: Fri Dec 08, 2023 10:10 am
Hi Ian,
Pretty sure 165/70s were mid 70s.
In the late 60s I had a sideline making 10x6 banded Mini & S wheels for Parramatta speed shop.
We all stretched 145-10 tyres over them back then!!
No they weren't tubeless. :mrgreen:
PostPosted: Fri Dec 08, 2023 5:23 pm
I thought it was in the 70s .... According to Mr Google, BMW introduced a 70 profile Pirelli tyre in 1968.... But I don't ever remember a 70 profile Mini tyre from Pirelli ...
My 850 didn't really need wide wheels but radial retreads were a real step up from the old Dunlop cross plies 8o..
PostPosted: Fri Dec 08, 2023 10:20 pm
I still have a set of Bridgestone RD-102 165/70HR10 's (worn & useless) from the late 70's on my set of minilites. I found them the best tyre of the day, though didn't wear real well. I also had a set of Pirelli's165/70 on a set of 4 spoke 10x5 100+'s on my S in the early 80's - bought from the Pirelli dealer at Red Hill Brisbane. Good tyre, wore well, good in the wet.
PostPosted: Sat Dec 09, 2023 11:28 am
I ran 165/70 Bridgestones in the mid 1970s on 7 inch wide Mawer and then widened Cooper S wheels. Now have a set of Yokohama 165/70 - AO32 Advans.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Mon Dec 11, 2023 7:11 pm
Many thanks for all your replies. It now depends on which brands I can get in Spain without having to import; charges are enormous!
