It is currently Wed Jun 25, 2025 4:23 am
PostPosted: Wed Jun 28, 2023 7:33 pm
Evening all, I have a 1970 Mk2 S block and I'm curious as to how these compare in bare weight to the solid chest 1100s blocks. Does anyone have figures to share?
My curiosity was sparked by a conversation with a mate who has a Chapmanesque obsession with weight reduction.
Tartanred
PostPosted: Thu Jun 29, 2023 9:17 am
On TM forum an unspecified 1275 bare block with caps was 32.205 kg. Thin flange, thick flange, tappet chest etc, no idea. I once experimented with drastic weight reduction in the mini: It involved going down the road on three only wheels......highly successful in weight reduction but my times strangely didn't improve. ( true story but kidding to make a point) . Pick the best , strongest block for lots of things BUT weight should not be one of those factors. There is /was a 500 ish kg mini on that forum ( Paul someone) where everything was targeted for weight reduction , and at one stage cost per kilo ratings brought up as well..... I am not sure if that particular thread is there but some very interesting reading.
PostPosted: Tue Jul 04, 2023 4:25 pm
Oh dear, worry, worry...
HI Tartenred
These are the weights i have for the blocks with in a kg or so as some blocks were not std bore.
MK 1 "S" thin flange 66 LB or 30KG
MK 2 "S" 71 LB or 32 KG
1100 "S" thick flange 74 LB or 34 KG
South African block 1275 35 LB or35 KG
998 thick flange 68 LB or31 KG
Hope this helps
Graham Russell
PostPosted: Wed Jul 05, 2023 7:22 pm
Thanks GR, that is very interesting and informative data.
Regards Matt
