It is currently Sat Jun 28, 2025 3:51 am
PostPosted: Sun Jun 06, 2021 9:12 am
Hey Folks, After some advice! During this time of covid, like many others I am trying to find things to so, so I stripped all the paint off my boolid (about 8 layers!) I have found a lot of rust in the clinch flange. Doesn't seem to be any between the inner and the outer surface but a lot just "inside" the clinch, as shown:
May be hard to see but the flange is actually lifting, and if you can see where I have lifted it all the way there is a lot of corrosion inside...
So is this worth repairing and if so what's the best way to do it, or would I be better off getting a better secondhand one?
I would like to keep it, if it's worth it, as it's the only original panel from my first car (1976 Mini that I bought in 1987 and re-shelled in 1988.). If a new panel is the way to go do Aussie bootlids fit on later UK minis?
Thanks Folks.
PostPosted: Sun Jun 06, 2021 9:38 am
It certainly looks saveable to me, there are a few ways you could go about it.
In order of preference
Unpick the skin, remove and have both parts bead blasted, then reassemble, seal seam.
Acid dip (complete) and rust treat then apply seam sealer around the panel seam
Irrigate seam with rust convertor and apply seam sealer
Good luck with it
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
PostPosted: Sun Jun 06, 2021 11:26 am
As the restorers say, if it casts a shadow it is restorable.
Cheers Dave.
