Mick wrote:
What make an model do you have?
Otherwise:
1. Drivers side underneath the bonnet drain channel, then across the bonnet catch panel
2. Headlight wires are in the loom, but split out to left and right underneath the bonnet catch panel
3. Driver's side, back corner, just beneath the wiring loom
4. Temp, oil and alt wiring is integrated into the loom. Oil Pressure is sometimes direct to the gauge, in this there is a pressure capillary tube which goes around the back of the engine and directly up to the instrument cluster throug the bulkhead.
Hi I have a round front 1967 but it has had a clubman harness fitted along side of the original and wires go everywhere and most are not connected
Thanks for your help
Sent from my SM-G960F using Tapatalk
