It is currently Tue Jul 01, 2025 4:51 am
PostPosted: Mon Jan 04, 2021 10:56 am
Does anyone know where I can get a cone compressor tool in Brisbane?
Also can I use it with the subframe out of the car?
PostPosted: Mon Jan 04, 2021 12:11 pm
When I had a car with dry suspension I used a bit of allthread, a piece of 1/4" plate and a few nuts....
Can be used out of the car
Not needed if you're putting in hilos
PostPosted: Mon Jan 04, 2021 12:45 pm
Rikki
There a couple of "How to" .... Classic Mini subframe Youtube builds done by Mini Mania in the US about four years ago. Even with the correct cone compressor it took a lot of leverage and effort. They also give the best sequence to fit the parts (including hi-los) to make the job easier.
Good Luck Dave D
