It is currently Wed Jul 02, 2025 10:54 pm
PostPosted: Sun Jan 03, 2021 5:00 pm
For the boot only use the triangular rubber which is hollow, it is a 90 degree triangle. I Have just changed the boot rubber there is probably different types available, Also screen rubbers I have just fitted the rear screen rubber, new rubber. It fits but the key rubber will not fit, not enough space for the key rubber. You will need to investigate where to get the correct screen rubbers. Check with your supplier if the fit,
Allen
