Mick wrote:
Minis aren't too bad. Try sitting in a modern car on any day, turn off the AC and see how long you last. I can only go minutes!
I think this comes down to the small surface area of the roof and the windscreens on a mini compared to a modern car (I'd say 50% less area).
I find you can park in the sun on a hot day and when it's time to leave open the door up wind the window down before you get in (this gives a few seconds for the hot are in the car to escape) then once your in drop the passenger window, pop the rear windows and off you go, within 30 seconds the cab is down to normal temperature for that day.
