It is currently Sat Jul 05, 2025 7:21 pm
PostPosted: Mon Nov 16, 2020 8:22 am
G'day all
I can't seem to find this info anywhere in the manuals
I'm replacing the bushes in my diff cage and crownwheel and am going to a machine shop to have them sized.
What clearance is required (1 thou?).
Also replacing the output shaft/sideplate bushes-what is the clearance required for these (1 thou?).
Thanks
Dave
"64 Smooth Roof Van (Colin)
PostPosted: Mon Nov 16, 2020 12:39 pm
I would give both the cage bushes 1 thou clearance.
This is also what I give the diff side cover bushes when bored after fitting.
Give the machine shop the pot joints or output flanges to measure.
I find the diameter of new pot joints can vary by up to a thou depending on brand.
If using old output flanges or yokes, if worn they can be machined down a few thou before boring the fitted bushes to suit. These bushes are 10 thou undersize approx.
PostPosted: Mon Nov 16, 2020 6:07 pm
Awesome-Thanks drmini :D
PostPosted: Mon Nov 16, 2020 7:45 pm
How did you get the bush out of the diff cage ?
PostPosted: Mon Nov 16, 2020 7:58 pm
I've not done one but if I did I would bore it out in the lathe, same as I've always done with primary gear bushes.
PostPosted: Mon Nov 16, 2020 8:32 pm
I left the old ones in the crown-wheel and cage and asked the machinist to bore them out and fit the new ones.
I did manage to easily replace the output shaft bushes but I don't have the equipment at home to do any machining.
