It is currently Tue Jul 01, 2025 7:55 am
 Post subject: Hydrolastic Bag Mixing
PostPosted: Fri Nov 06, 2020 4:27 pm
Is it ok to have Cooper S rear bags with Mini front bags.
PostPosted: Fri Nov 06, 2020 5:13 pm
I seriously doubt would make any difference so long as the bags on the same axle are matching, I think the difference between an S bag and a normal mini bag is in the spring rate, so maybe your rear suspension will be stiffer than the front by a smidge...
But after 50+ years I don't think there could be all that much difference between bags anyway...
PostPosted: Fri Nov 06, 2020 5:23 pm
Agree with simon k.
My mini K has standard displacers front and rear with added standard shock absorbers on the front. I can't notice the difference between that setup and the Mk2 S with correct S displacers.
PostPosted: Fri Nov 06, 2020 8:37 pm
it will not make any difference ,you should fit competition bump stops When fitted there is hardly any load on the displacers and the displacers will last much longer , also the car will handle better .Approx $100 Karcraft.
Allen
PostPosted: Sat Nov 07, 2020 5:59 am
Allen
I agree re the rear. However I found comp ones too high at the front unless trimmed, so fitted std ones there.
My car now sits level with S/GT bags in front and Mini K/Matic in rear.
Users browsing this forum: Bing [Bot] and 107 guests
