Ignore where it says `copper washer to seal'. No need, it's Loctited in.
Also, the title block says 1275. This mod works on any Mini box.
I can't edit this, I'm retired and now CAD illiterate.
Also, hexagonal bar is better than round to tighten it up. I used hex on the last couple.
Looks good to me. I can knock a new one up with those details altered and put it into the How To that you write.
Do you cut the threads with single point on the lathe or use taps/dies?
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
