It is currently Tue Jul 01, 2025 12:44 pm
PostPosted: Thu Sep 17, 2020 6:51 pm
Cant seem to find the noise, mainly happens when going slow over bumpy roads any ideas ? everything is new
Allen
PostPosted: Thu Sep 17, 2020 7:12 pm
Did you use rubber or nolathane/poly bushes on your suspension?
Poly tends to squeak if not lubed up, might be work considering that?
Sent from my Pixel 3 XL using Tapatalk
PostPosted: Fri Sep 18, 2020 6:47 am
From the post subject, I assume your squeaks are coming from the hydro displacers. If this is correct, did you clean your bags with methylated spirits? If so, there may be residual metho still in the displacers.
I have cleaned my displacers with metho and then they were stored for over two years in a 50/50 mix of metho and glycol.
If you do a forum search, you will find evidence that people have got squeaks in their displacers, if they used metho in their fluid mix. With the 50/50 metho cleaning mix, I found that I could get a definite squeak from the displacers even playing around with them by hand. I am using a 50/50 glycol/distilled water mixture in my displacers and found that I needed to clean them 3 or 4 times to get rid of the squeak from the metho.
I have just reinstalled my displacers back in the car. In the next week or so, I should have my car back on the road. Hopefully, I do not get the dreaded metho squeak.
PostPosted: Fri Sep 18, 2020 8:54 am
ok thanks ,the squeak sounds like metal to metal I have already moved the grille forward because of the oil cooler.Squeak is still there I may have to put the car on a hoist.
Allen
PostPosted: Fri Sep 18, 2020 10:13 am
1. Check your bayonet fitting of the bag into the (sub)frame - or integrity of frame, fatigue / cracks where bag locates
2. (Replaced?) caged needle rollers and shaft used into the top arms - wear already possibly evident with poor metallurgy properties
3. Nylon cup and ball
PostPosted: Fri Sep 18, 2020 11:45 am
My guess is the knuckle joint has worn through the nylon cup.
PostPosted: Fri Sep 18, 2020 1:33 pm
Online
That is the most common cause of squeaks in hydro. Was going to suggest it too, but Allen said everything was new. But I replace the grease in the new ball/cup with something I recognise.
If the squeaks are from the displacers, was the fluid branded or home brew? Squeaking displacers were a problem in the early years of hydro but fixed with a change to the fluid formula.
Allen may not have much control over the fluid used by someone else.
PostPosted: Fri Sep 18, 2020 2:09 pm
It’s funny how the terminology changes through the years. In my day working in a BMC dealership, they were called a strut foot and the nylon cup was a strut foot seat.
My comment is not being critical of anyone.
PostPosted: Fri Sep 18, 2020 2:25 pm
Yes, interesting how differently parts are described in the BMC literature versus the workshop. I'm sure we could make a long list of alternative names for various parts.
Had a quick look in the Mini parts books and see that the term knuckle joint and ball socket were used to describe these parts from the first 850 through to the Clubman and Leyland models.
PostPosted: Fri Sep 18, 2020 5:50 pm
Thank you Doug
PostPosted: Mon Sep 21, 2020 4:51 pm
Thanks for all the assistance I have found the problem, the grille was new when I did the resto the rivets that hold the grille bars are loose hence the metallic sound .
Users browsing this forum: Bill B and 124 guests
