It is currently Fri Jul 04, 2025 4:26 am
 Post subject: Door Lock barrel
PostPosted: Wed Jun 17, 2020 1:00 pm
Where can I get this door lock barrel to suit 1969 Mini.
 Post subject: Re: Door Lock barrel
PostPosted: Wed Jun 17, 2020 2:08 pm
The BMC part number is HYA3087. I doubt you will find any new ones being sold separately to the handle but give it a try. It's made by Wilmot Breeden P/L.
The usual solution is to get the barrel out of a boot handle. It will need to be trimmed down in a lathe to suit the door handle as there's a slight difference. If you compare the two side by side you will see what material needs to be removed.
PostPosted: Wed Jun 17, 2020 4:14 pm
So I am on an impossible mission to buying a new barrel?
PostPosted: Wed Jun 17, 2020 4:35 pm
Never say never, but I'm not aware of a source. Second-hand would seem to be your most likely option.
PostPosted: Wed Jun 17, 2020 8:16 pm
How close would these door & boot tumbler sets for a Mk1/2 UK mini be? I'm sure that BMC Aust minis always used W&B locks and keys and doubt they would ever have been local manufacture.
http://www.minispares.com/product/Class ... 0to%20shop
PostPosted: Thu Jun 18, 2020 8:02 am
Do you want new, or one that can be repaired/re-keyed by a locksmith?
PostPosted: Thu Jun 18, 2020 8:23 am
Either or both, just let me know what you have.
PostPosted: Thu Jun 18, 2020 3:09 pm
I don't have any new, but have a number of boot handles complete, one with key, the others not, but the locksmith I use seems to have a stock of bits.
Also have a door lock; the escutcheon is damaged (the remover seems to have forgotten the 3rd screw) but the barrel is there and seems undamaged externally.
PostPosted: Thu Jun 18, 2020 3:19 pm
I have sold him a new UK MK 1 barrel and key. It looks close to his pic.
But no guarantees it'll fit.
PostPosted: Thu Jun 18, 2020 7:12 pm
my lock barrel was frozen in the handle, my locksmith gave up. I spent over 6 month's on and off getting it to free up and work smoothly. Tried Protecta lock that the locksmith recommended, wd 40 , diesel, a product called yield, and 50% acetone and auto transmission fluid. I left it in the freezer then in the sun on a 40 degree day. It now works perfectly. Persistence won. Most locksmiths can download the key information and provide you with a key, mine cost $22.00 and $11 for a second key. Somerford mini can supply keys cut to the FS number.
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
PostPosted: Wed Jun 24, 2020 7:15 pm
Users browsing this forum: Bing [Bot] and 111 guests
