It is currently Sun Jul 06, 2025 11:16 am
 Post subject: Front Tie Rod Bushes
PostPosted: Sun May 31, 2020 10:29 am
This is what is left of my orange front tie rod bushes. The car has not been on the road for many years but they have disintegrated away.
 Post subject: Re: Front Tie Rod Bushes
PostPosted: Sun May 31, 2020 10:38 am
quality....
PostPosted: Sun May 31, 2020 10:45 am
Rats and Mice?
PostPosted: Sun May 31, 2020 12:57 pm
simon k wrote:
quality....
Red poly crumbles under load, my tiebar bushes did the same. It's too hard & brittle.
I went back to rubber.
PostPosted: Sun May 31, 2020 5:03 pm
simon k wrote:
quality....
Would this also apply to the life expectancy of the Nolathane red hex bush replacement for the original felt steering rack damper?
PostPosted: Sun May 31, 2020 8:48 pm
I have had the same problem in my mini and ford, but i found them to fall apart with age. I did what drmini did go back to rubber but superpro ones are very good i have fitted a few.
Cheers Rob
PostPosted: Mon Jun 01, 2020 6:26 am
Bill B wrote:
simon k wrote:
quality....
No. Because it is lubricated, usually with 140 gear oil. And there's hardly any compression stress on it.
Also, although these are also red, they are far softer than tie bar or steady bar bushes.
I've pulled some racks down that had them in and they were still perfect. But I changed them due to rebuild.
PostPosted: Mon Jun 01, 2020 10:06 am
Thanks for that answer.
PostPosted: Mon Jun 01, 2020 9:38 pm
You should not put a polly bush where it appears it might have been in the photo...
The tie rod moves up and down and the joint needs to be able to flex. (I missed the lamp post by thiiiiis much after a tie rod end failed. If the joint can't flex, the rod does...)
Movement at the tie rod end under heavy braking (as the front bush deforms) causes caster changes which affect stability. This is why you use a polly bush in front to maintain stability under braking and a rubber bush behind where it doesn't have much of an effect on acceleration but allows flexibility over bumps...
My (front) polly bushes have been there for years.
Cheers, Ian
