It is currently Thu Jul 17, 2025 4:35 pm
PostPosted: Fri May 22, 2020 8:30 pm
Hi
just wondering if you can still get the chrome finisher inner strip for 1969 wind up door?
Its the internal chrome strip for drivers side. I've searched the net but don't know what part number to look for and not sure of the whether its called a molding or finisher strip. guessing i am looking for a needle in a haystack.
guidance appreciated thanks.
1969 Mini k
2006 Cooper S
PostPosted: Fri May 22, 2020 9:07 pm
HYA2892
PostPosted: Sat May 23, 2020 1:54 pm
cooperess wrote:
HYA2892
According to Mini King catalogue, that part number is the "door pocket mould" - with the bend at both ends.
Does Minik1969 mean the strip across the top of the door where the window slides, where the fluffy draught excluder attaches, and with slightly rounded ends?
PostPosted: Sat May 23, 2020 2:28 pm
Here is a photo of the door moulds.
From left to right: internal window slot; external window slot; door pocket top edge.
I think you are wanting the LH mould in the photo.
PostPosted: Sat May 23, 2020 3:21 pm
Yes, i think its the internal window slot as the fluffy bit sits on the other slide. As you mention. Not the curved bit for the pocket.
Ive seen you can get the chrome strip for sliding window cars but wondering if that part was changed when the aussie cars had windup windows.
1969 Mini k
2006 Cooper S
PostPosted: Sat May 23, 2020 4:20 pm
HYA2749 is the retainer at the top of the door where the door liner slots in.
PostPosted: Sat May 23, 2020 4:58 pm
Is this the mould you mean? Your comment about sliding window parts threw me off a bit.
It might be p/n HYA2791. Winabbey might be able to confirm it.
If this is what you're after I do have a spare. They fit either side.
PostPosted: Sat May 23, 2020 8:45 pm
Yes, the one your arrow is pointing too is the one I mean.
1969 Mini k
2006 Cooper S
