It is currently Sat Jul 05, 2025 5:18 am
 Post subject: Gear Box Conversion
PostPosted: Fri May 01, 2020 10:54 am
What parts are required to convert a Cooper S Mk2 gear box to an 18mm 3rd motion shaft from a 14mm, apart from lots of $$$.
 Post subject: Re: Gear Box Conversion
PostPosted: Fri May 01, 2020 11:08 am
I get a local toolroom to machine the end down and press fit an 18mm dia hardened bearing inner sleeve. If it ever wears it is replaceable.
PM me for details.
MUCH cheaper than buying a new aftermarket shaft.
You will also need to buy an S/GT 1st motion shaft DAM3167,
and the 18mm needle bearing.
Edit:
PM replied.
Users browsing this forum: Bing [Bot] and 86 guests
