It is currently Sun Jul 06, 2025 6:09 pm
PostPosted: Sun Apr 05, 2020 5:15 pm
Hi,
I have six more bits to identify... and then the rest can go in a box for the time being.
In the last lot ALL Mini bits were identified and there were a few unknowns and questionables.
I have tried to search for these beforehand with no luck.
Already found:
1. Distributor to block flange
2. Oil pressure sender - electric gauge
3. Hydro hose nylon protector sleeve retainer
4. Speedo drive worm. Engages 3rd motion shaft in gearbox.
PostPosted: Sun Apr 05, 2020 5:42 pm
PostPosted: Sun Apr 05, 2020 5:43 pm
1. Distributor mount
PostPosted: Mon Apr 06, 2020 5:56 am
PostPosted: Wed Apr 08, 2020 6:53 pm
Sorry but I don't believe that is correct. The gear you are thinking of has a shorter shaft with flats on the end to allow it to fit in the end of the 3rd motion shaft.
Maybe a similar part from a different BMC gearbox though.
PostPosted: Wed Apr 08, 2020 7:26 pm
You are right, I didn't look close enough. :oops:
Maybe Morris 1500? or 1800? Dunno...
PostPosted: Wed Apr 08, 2020 8:14 pm
It looks like the speedo drive out of an automatic.
PostPosted: Thu Apr 09, 2020 5:38 am
5. Internal Mirror mount. Glues to screen and mirror foot slides over it.
