Hi Allen
A good map will improve your performance, BUT you need to know what you want first. The black box users, ( megajolt stealth etc) and the programmable users ( CSI and 123) will be able to share the key parts of the curves that work for them. If you are planning to tinker yourself, i would just make sure your dizzy cam isnt too wide ( say 11 or 13 but not 15 dizzy degrees)and know what the vacuum is doing ( if you have one).
Just as an example, , , go to the CSI ignition website and nose around in the technical info area. Here are some of their curves
http://www.csi-ignition.nl/bestanden/mi ... curves.pdfAs an example of the important bits of the curve ---------Below I am now talking about timing light degrees
Static 10degrees
Rapid rise , so i am at 22degrees at 2000rpm
More gradual to be all in ( maximum advance 30degrees) at anywhere above 4000rpm
I have a 1310 cc mild road motor ( 260 camshaft) with an early non vacuum CSI dizzy and find curves 11 and 13 work pretty well. I am not worried by maximum advance at 32 because i rarely if ever get up to 6000rpm.
IMO a number of these curves ( and those in the 123) are unsuitable mainly because they are too slow to advance.
When i change something on that motor ( eg different carbs), i use the curves and an AFR to 'optimise' - but apart from that i use one curve.... you only need one , but it needs to be the right one
