It is currently Sat Jul 05, 2025 12:33 pm
 Post subject: Oil Pump Bolts
PostPosted: Sun Mar 22, 2020 6:16 pm
Replacing pin drive oil pump in my S engine. The new pump is Mini Spares C-AEG410 which has four bolt holes. The old pump was a three bolt HE type pump (Birmingham 5367-C stamped on the body) and the bolts were secured with a half moon all in one lock washer.
The body on the old pump was slightly wider than the MS one meaning the old bolts are too long and bottom out. I can cut the old bolts down a bit to overcome this, but the old lock washer won't fit of course. Did the four bolt pumps use spring washers under the bolt heads? no washers? or was there a special all in one lock washer set up for this pump too?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
 Post subject: Re: Oil Pump Bolts
PostPosted: Mon Mar 23, 2020 4:49 am
Fit new spring washers and shorten the bolts.
For peace of mind you could Loctite the threads but I've never had them come loose.
PostPosted: Mon Mar 23, 2020 4:40 pm
Thanks Doc, I didn't think there was a continuous lock tab washer for the 4 bolt pumps.
Slide
