GuamMini wrote:
Thank you so much, How do I static set the timing with a test light with a breaker less ignition (no points)
Timmy’s right ...just set max advance at around 28deg at 4K+
Or... use the method I suggested in the 850 timing post to get it right at idle.
Both methods depend on having the correct advance curve built into the dizzie ...
One method I have used to set the static timing with an electronic ignition (a Piranha IR trigger) is to set your transistor radio (if you’re old enough to remember what that is
beside the dizzie and tune is off station..so that you get an even static sound (allegedly the background radiation from the Big Bang;). Now twist the dizzie as you would with points; as the ignition trigger fires you will get a sharp burst of louder static....
Cheers, Ian
