It is currently Tue Jul 08, 2025 6:00 pm
 Post subject: Advise on gearbox part
PostPosted: Tue Jan 07, 2020 6:11 pm
Preparing to rebuild a 4 synchro remote gearbox, washing and cleaning some new parts.
This is the new 1st/2nd gear synchroniser I bought some time ago for the job.
I thought it was from Mini Spares but the plastic bag didn't have their usual tag - just a texta part number, but the assembly came with a "genuine" piece of string tying the 2 parts together.
My problem is that the inner hub and outer cone don't look like they are aligned correctly: the inner hub has 3 cut-outs. However they don't match the 3 gaps where the outer cone has gaps in the gear teeth.
The workshop manual covers the 3 synchro gear, but not much on the 4 synchro setup.
Can anyone confirm the outer ring should move 2 splines clockwise (before I start chasing detent balls)?
Thanks all.
PostPosted: Tue Jan 07, 2020 6:27 pm
Online
It's just been assembled out of position. Put in a plastic bag and push apart.
I have a tool to fit the balls and springs but you can use a big hose clamp or a piston ring compressor.
Post it up if you like, me fixum. :)
PostPosted: Tue Jan 07, 2020 7:22 pm
Thanks for the offer and the information.
Reassembly isn't a problem. Have already cleaned and assembled the 3/4 hub.
Just needed confirmation this one was out of position.
Thanks, again.
PostPosted: Wed Jan 08, 2020 8:39 am
Offer was not taken up on this occasion, but what a selfless offer by drmini, what a great bloke!
1972 Leyland Clubman, 4EFTE 1330cc Turbo, 220Hp on 17psi
(1/4 mile: 13.8s @108mph @168Hp)
PostPosted: Wed Jan 08, 2020 10:23 am
Agreed.
An all-round 'useful little engine".
PostPosted: Thu Jan 09, 2020 12:55 pm
Make sure you assemble the inner and out the correct way around. The long boss in the centre points in the same direction as the long boss on the outer.
If you get this wrong, it will all go back together OK, but from memory synchromesh on second won't work.
PostPosted: Thu Jan 09, 2020 4:31 pm
Thanks for the comment. I am aware of the alignment but it's worth you mentioning it. You don't know what I don't know (I think I got that right) but I appreciate your reminder in case I didn't. Thanks for the thought.
Users browsing this forum: drmini in aust and 71 guests
