It is currently Wed Jul 09, 2025 9:36 am
 Post subject: Where does it go?
PostPosted: Fri Sep 27, 2019 9:57 pm
I bought the car in bits and as it is my first Mini I am having fun working out where the bits go but this bracket has me beat. Please help!
 Post subject: Re: Where does it go?
PostPosted: Fri Sep 27, 2019 10:02 pm
Front number plate bracket.
PostPosted: Mon Sep 30, 2019 7:19 pm
Excellent thanks, looks easy when you know where to look!
Now my next problem, I have replaced the steering rack, OK job with the engine and interior out, and in one of the boxes of bits I found the blinker switch shroud but it appears to be too long. With it against the column mounting bracket it comes up past the steering wheel by a couple of inches. Are there different shrouds or possibly not the right column as it was only loosely fitted to steer the beast when I bought it.
PostPosted: Mon Sep 30, 2019 7:41 pm
You've got the number plate bracket upside down :wink:
PostPosted: Tue Oct 01, 2019 8:37 am
There are different length steering columns and 2 different shrouds.
You probably have a later column which is shorter, you need the mk2/later shroud which is also shorter.
(and usually cheaper)
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Tue Oct 01, 2019 4:36 pm
I didn't know that either. How much shorter are they? My steering column is way too long and I'm 189cm and have the seat right back. Would love a shorter steering column.
PostPosted: Tue Oct 01, 2019 7:19 pm
Thanks for that, I'm not sure how the blinker switch/horn etc fit up either but I have plenty of time to worry about that as it's off to the painter in the next day or so.
PostPosted: Wed Oct 02, 2019 11:29 am
I am not sure exactly of the difference in lengths but it is significant. 80mm maybe?
Ford DF LTD - 5Ltr
PostPosted: Wed Oct 02, 2019 1:21 pm
FirstMini, I'll swap you my long column for your short one :D
PostPosted: Wed Oct 02, 2019 1:22 pm
Thanks MINI66, that would make the world of difference.
PostPosted: Fri Oct 04, 2019 5:44 pm
If you were a bit closer to Central Vic. I'd do that happily.
