It is currently Wed Jul 09, 2025 4:23 am
 Post subject: Fuel tank breather Query
PostPosted: Mon Sep 23, 2019 5:50 pm
Hi all,
Some of you may remember that my old LH tank looked pretty average and was full of pinholes.
Today I am really greatful to have picked up a replacement s/h tank that appears to be in pretty good condition.
My question is, my original tank had the breather coming off the flanged piece of the tank & this one comes from the filler neck... what tank is this from? Later I'm assuming... it also doesn't have a drain in the bottom of the tank, I'm unsure if it has been removed or came like this from factory.
Is it worth having the drain it or not?
Either way, really happy with the replacement tank, just curious about the differences.
Thanks [GRINNING FACE WITH SMILING EYES]
Sent from my SM-G960F using Tapatalk
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Tue Sep 24, 2019 11:48 am
Rohan, Tank is the original tank from 1978 998LS.
PostPosted: Tue Sep 24, 2019 11:55 am
It’s got the factory dent in the corner near the taillight. The drain on mine is a real pain as you have to remove the drain valve to take out the tank. It’s much easier to remove a hose from the fuel pump if you need to drain it
