It is currently Wed Jul 09, 2025 10:52 pm
 Post subject: 1978 Brake lines
PostPosted: Mon Sep 16, 2019 8:00 pm
Ok so I've had the brakes rebuilt and I'm putting it all back together but the lines from the dual line master cylinder to the valve thingy are a pain in the arse.
I have ordered both lines from two different online Australian mini stores and both times the ones that they sent are wrong. It appears that the brake line ends that go into the valve thingy are metric?
Is that correct?
EDIT October 1978.
 Post subject: Re: 1978 Brake lines
PostPosted: Tue Sep 17, 2019 7:41 am
yes metric on the valve block end with a 10mm hex, imperial on the other end with a 7/16 hex.
PostPosted: Tue Sep 17, 2019 11:01 am
Metric both ends
PostPosted: Tue Sep 17, 2019 4:33 pm
FFS!!!! which is it?
PostPosted: Tue Sep 17, 2019 5:11 pm
Australian dual system master cylinders are metric 10mm
the 5 port pressure regulator valve are metric 10mm
GMC227 dual system master cylinders are metric 1x10mm +1x12mm
all other fittings are imperial 3/8 unf x 24tpi
Users browsing this forum: Barkfast, Bing [Bot] and 108 guests
