It is currently Wed Jul 09, 2025 1:03 pm
 Post subject: upper control arm repair
PostPosted: Sun Sep 01, 2019 3:24 pm
G'day People,
I am in the process of repalcing the knuckle joint on one side of my front hydro suspension.
If the knuckle has worn through the nylon cup into the actual arm, is there a diy method to repair?
i.e., JB WELD stick or similar?
Appreciate any feedback
PostPosted: Sun Sep 01, 2019 3:36 pm
Put Araldite in bottom of hole, then push the new cup in.
PostPosted: Sun Sep 01, 2019 4:04 pm
Yep, I have used Araldite in the bottom and it works great. It supports the bottom of the cup as the mating surface is no longer angular but circular. Have a read of this - http://www.dsnclassics.co.uk/technical- ... placement/
PostPosted: Sun Sep 01, 2019 4:13 pm
JB Weld is also OK. Not too much though as you want the cup to sit down in its original position. Consider some Vaseline or other lubricant on the bottom of the cup when you push it down so it doesn't stick to the filler and is then easier to remove later. In fact if you remove the cup when the filler has dried you can redrill the very small hole at the bottom, then refit the cup.
Users browsing this forum: Andosoft and 69 guests
