It is currently Thu Jul 10, 2025 10:19 am
 Post subject: Plug Gap with Pertronix
PostPosted: Sat Aug 24, 2019 12:36 pm
With my 1330cc what’s a suggested plug gap when running a Pertronix Flame Thrower Coil and Pertronix module? Currently running NGK BP5EY with .030’ gap. Should I open it up to .035’? Or leave things be? All running fine otherwise.
PostPosted: Sat Aug 24, 2019 1:31 pm
Hi, I do not believe you should open it up. That does not have a big spark output, and you risk misfiring as every single gap in the system uses some spark , leaving little for firing the hard to burn ULP
cheers Lindsay Siebler
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Sat Aug 24, 2019 3:30 pm
Stronger spark with less area versus weaker spark with bigger area .As long as the spark causes combustion then which is best .Any engineers here?
PostPosted: Sat Aug 24, 2019 4:01 pm
If you go too far, you will get a low speed misfire during warmup when cold.
I used to run .035" with a Bosch GT40 and a Pertronix ignitor, but it would misfire at .040".
I agree with lomin, .030" is best.
PostPosted: Sat Aug 24, 2019 4:57 pm
No worries. Left at .030. Cheers.
