It is currently Fri Jul 11, 2025 6:25 am
PostPosted: Wed Jul 10, 2019 5:22 pm
Just thought I would share something I learnt.
I recommend not holding the clutch in when you start you mini otherwise you run the risk of damage over time.
As the gearbox and motor share the same oil it take sometime for it to get into all the moving parts. Starting your mini with the clutch in puts pressure on the bearings before the oil can get to it.
Put your mini in neutral and before starting and leave your foot off the clutch.
Not a real expensive lesson but a time counsuming one.
