It is currently Fri Jul 11, 2025 6:18 am
PostPosted: Wed Jul 03, 2019 10:06 am
Hello all, I'm having this problem with my Mini but also with other classics lately, in that I can't seem to find rubber fuel hose that lasts more than a year or two without perishing and leaking - it's the second time in 12 months I've had to change the fuel hose between the tank/pump and pump/fuel line in the 850 - I've used hose from several different auto parts stores - the hose is not curved/under tension or subject to excessive heat but it still keeps perishing, splitting and leaking.
Looking for recommendations please on what type/brand of fuel hose others are using - if anyone has suggestions on a particular brand or info of a supplier it would be greatly appreciated. TIA.
+ Too many other classics
PostPosted: Wed Jul 03, 2019 10:35 am
What fuel do you run?
Ethanol?
Sent from my SM-N960F using Tapatalk
PostPosted: Wed Jul 03, 2019 10:39 am
Nope, just a stock standard 850 running on BP ultimate 98 + flashlube
PostPosted: Wed Jul 03, 2019 1:04 pm
Are you using normal fuel hose or EFI hose?
PostPosted: Wed Jul 03, 2019 1:48 pm
weird - never had a problem with fuel line bought from the usual places...
PostPosted: Wed Jul 03, 2019 2:21 pm
always use EFI hose as it seems to last better with todays quality fuels
PostPosted: Thu Jul 04, 2019 7:50 am
I use Dayco USA fuel hose, designed for E10 unleaded. I used it to join the RH tank.
It stays flexible, I changed it after 10 years but it was still fine.
PostPosted: Thu Jul 04, 2019 8:10 am
Good advice Kev...nothing worse than seeing a fuel hose turning to jelly an wondering what it has done to your fuel system...
PostPosted: Thu Jul 04, 2019 6:51 pm
Hi, I agree with DDK. The so called rubber in most items is nearly always rubbish. Today I have just replaced less then one year old EFI hose that was perished on the outside., under the rear, no sunlight. I thought it was in gates boxes when I bought it, but it is extremely hard to know if any rubber product is ok. I am now trying Eecel brand, made in Malaysia, cross fingers. I attempt to give chinese and indian rubber a miss., but who really knows
10 years ago I bet it was quality, genuine OEM stuff lasts almost forever , why can't the aftermarket ? and the answer is because they are doing it for a low price, and they do not have to meet OEM quality checks
Another mini owner is a rubber specialist, and tells me a lot of rubber is recycled and chemically reconstituted
He says you can taste and smell the chemicals.
How many of you have had to throw away ball joint boots, cv boot, tie rod boots, petrol tank grommets, the list goes on, and it is the same for every make. Very frustrating
I try to reuse as many original genuine rubbers as I can.
Cheers Lindsay
" Its the rubber products that let you down"
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Fri Jul 05, 2019 7:47 am
Cheers Lindsay
Well said Lindsay...unfortunately, fairly normal these days...
