It is currently Fri Jul 11, 2025 4:43 am
PostPosted: Sat May 25, 2019 8:08 am
A previous owner installed the 3 gauge pod in my Mini Window Van.
Question #1 - what coloured wire connected the Coil & Tachometer? Was it perchance Blue & Yellow? (I ask because I can not find any Blue & Yellow wire in the wiring diagrams in the OZ Leyland Mini Manual)
Question #2 - I am using a 123 Distributor, does this dizzy present any incompatibility with the tachometer in the cluster?
PostPosted: Sat May 25, 2019 12:43 pm
Rick...which " OZ Leyland Mini Manual" do you have?
The Gregory's has white wire from fuse panel to the coil...then White/Black to the Dissy...
PostPosted: Sat May 25, 2019 1:18 pm
I'm not confused about the Ignition wire to the coil & the connections from the 123 dizzy to the coil.
What I am puzzling is the Blue/Yellow wire with small circular connector...is it the Tachometer connection? (given my non-standard 3 gauge pod installed by previous owner)
PostPosted: Sat May 25, 2019 1:47 pm
SOLVED - I have been advised by the person who did the work that the Blue/Yellow wire was added because the Window Van never had the 3 gauge pod and needed to have the tach in the 3 gauge pod wired up. The wire in question goes to the Negative side of the coil!
PostPosted: Sat May 25, 2019 4:00 pm
Good...I was looking at both Clubman GT and Van diagrams for the coil and instrument circuit board wiring...no Blue/Yeller were jumping out of the pages tho...
