TartanRed wrote:
Ever since I wired up a very nice period Smiths RVI 8k tacho in my 850, the ignition has been crap. The car has been impossible to start and has run like a chaff cutter with a hairy goat stuck inside. Strangely enough, the tacho itself was working beautifully, with a stable needle and as accurate as a modern VDO unit that I borrowed out of my race car.
Now these old Smiths tachos use the ignition coil to distributor circuit to provide the impulse signal for the tacho. However you end up with a very long ignition LT wire, often with several connections to pass through the firewall etc. Too many points of failure for the ignition system and plenty of room for gremlins to creep in...
Having disconnected the tacho on Friday night and restored the original coil to distributor wire the car is running perfectly again (still on good old points, albeit 32 ounce S points) I took it for a good run up a steep hill and it was pulling like a train. So, how to get the RVI tacho to work, and still have a functioning ignition?
I found a tip on the Mk 1 Forum and thought it was worth a try. Leave the normal coil to distributor wire in place and wire the tacho impulse circuit in parallel. I was sceptical, but it is working perfectly. The tacho is happy and I have a good solid ignition!
Yep...can cause problems...and with Electronic Ignition, you could try this...
